Lastdataedit no default
Hi This is one version 2.0.3
I have seen various problems with the lack of default but not this one.
I get
xibo SQLSTATE[HY000]: General error: 1364 Field ‘lastDataEdit’ doesn’t have a default value Exception Type: PDOException
When trying to create a dataset or import a layout with a dataset.
Any help please
ScreenHunter%20216
I have created an issue for it - https://github.com/xibosignage/xibo/issues/1878
As a workaround before we release 2.0.4, you can manually run the following sql queries to fix the problem:
ALTER TABLE dataset MODIFY `lastDataEdit` int(11) DEFAULT 0;
ALTER TABLE dataset MODIFY `lastClear` int(11) DEFAULT 0;
Thanks a lot Peter worked a treat
