Issues on Github
Why no Issues/Bugtracking on Github is activated?
Because i found many Issues on 1.8 Beta.
There are 29 open issues regarding 1.8 beta (which will be the next stage for 1.8)
If you’ve found any issues that are not covered in GitHub, please make a a new post in ‘Dev’ category, detailing the issue - if we can confirm it we will then add it to GitHub.
To clarify - please report your issues here first - we then verify the bug and create the issue on GitHub.
OH :smile: And i search on xibo-cms. Problem Solved.
