When you are in the campain menu, and you try to add layouts inside the campaign, you can search for tags. But the tags are not correctly displayed (no really cool blue box effect). Is it intended ?
Thank you,
Rodolphe from A2Display
Thank you,
I see what you mean, ie the difference between:
the latter is just a text, although as far functionality is concerned it is the same.
Perhaps it would be good if that was consistent throughout the CMS, I’ve logged enhancement issue for it.
