I upgraded to 2.2.1 a couple weeks back and I just noticed that I’m having some issues with the new ianw/quickchart container. It will not start and is continually in a restart state. When I pull the logs, I get:
yarn run v1.19.1
$ node index.js
error Command failed with signal “SIGSEGV”.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
I noticed this after my CMS instance was completely unresponsive this morning (a restart cleared it up, but I fear it will continue).
We don’t make the quickchart software, so you’ll need to report any issues with it directly to that project:
If the latest version doesn’t work for you, then you can work around by pinning to an older version by editing your docker-compose file and on the image line change
image: ianw/quickchart
for
image: ianw/quickchart:v1.2.0
Which is the previous version. You’ll need to up containers afterwards to apply that.
