We have encountered an issue uploading files to our Library in the CMS. When we attempt to upload a file we receive the error “File is too Small”. I have tried different file sizes ranging from 164 kb to 15mb with no change. We have recently migrated our CMS to a new server, this also entailed a version change from 1.8.13 to 2.3.2. Prior to the migration and update the upload to Library worked fine. I have checked permissions on both the Library and Web folders and I believe they are set correctly. I have also tried going up to Version 2.3.7 without any resolution to the issue.
I have enabled debugging and this is the last upload related Log Entry I can Find
Hand off to Upload Handler with options: {“userId”:1,“controller”:{},“oldMediaId”:null,“widgetId”:null,“updateInLayouts”:0,“deleteOldRevisions”:0,“allowMediaTypeChange”:0,“displayOrder”:null,“playlistId”:null,“upload_dir”:“C:\inetpub\sites\Xibo\LIB_Files\temp/”,“download_via_php”:true,“script_url”:"/library",“upload_url”:"/library",“image_versions”:[],“accept_file_types”:"/\.mp3|wav|swf|ttf|otf|eot|svg|woff|js|html|htm|htz|jpg|jpeg|png|bmp|gif|pdf|apk|ipk|wgt|ppt|pps|pptx|json|wmv|avi|mpg|mpeg|webm|mp4|m4v$/i",“libraryLimit”:0,“libraryQuotaFull”:false,“expires”:0}
Server Specifications
- Server 2016 with IIS
- PHP 7.2.31
- MySQL 5.6.49
Thanks in advance for your assistance.
