Is Xibo HTTP/1.1 compliant?
My API gateway responds with Transfer-encoding:chunked. Xibo doesn’t seem to recognize this, just wondering if Xibo is HTTP/1.1 compliant?
Can you be more specific? In what way are you consuming the API?
Have you put Xibo behind a gateway and do you mean are the Players HTTP/1.1 compliant?
