Is there a way to make borders?
Is there a way to make custom borders to go around each layout so they look consistent? Or is there a way to bring one over from PowerPoint?
If so, please let me know as soon as you can. I am in the process of creating 40+ layouts and it would be much appreciated to have that.
You could have a layout background image with that perhaps and then use that to design the layout?
You could also have this layout with layout background saved as a Template and then select it when you create new layouts.
I will try that. Thank you!
Just did what you said and it worked. Thank you for your time
