Is there a way to automate Xibo client install
Hello community,
I am wondering: is it possible to automate the install of the Xibo windows client?
In particular: if I would manage to run the .msi installer automated, could I somehow generate a hardware key to put in the config.xml or let a hardware key/connection be generated without user intervention (so automating the client config that starts after the install)?
Thanks in advance for the input!
Greets,
Jimmy
The hardware key just needs to be a unique string so you can use any way you want to generate that string and write it in the XiboClient.config.xml file in %APPDATA%
