Is it possible to place the uploads files on separate folders?
Hi There,
Is it possible to separate the uploads files?
For Example:
xibo-lib/images
xibo-lib/videos
xibo-lib/flash
Thanks for the support.
Cheers
Hi, sorry that is not possible. The storage of files is not guaranteed to remain the same either so you should assume that only the CMS should access its library.
