Is it normal to have many directories under /cache/stash
Hi… is it normal to have under “Library Location” /cache/stash/ and loads of directory under it ?
like this “/cache/stash/0fea6a13c52b4d47/25368f24b045ca84/b8ac4316b44f99ee/f0cf6447439815bc”
iam running Version 1.7.7
Regards
T
Yes. It’s the Player cache for calls to the webservice.
You can safely remove them at any time, but they will be recreated as Players connect.
Assuming you are running maintenance, then old files/folders will be pruned periodically as part of that routine,
Thanks for the reply Alex
