Installing help
I’ve downloaded the cms files and created a folder in htcdocs called xibo. I’ve configured xampp and fixed the two php errors i had. The usual max file upload and internationalization issues.
When i retest, everything is good, but i don’t get the ‘next’ option. In all of the documentation next to the ‘retest’ button there should be a next button and i’m not able to move to the next section.
If the Next button isn’t showing then you still have a dependency issue in the list. Make sure every item in the list is ticked. There will be one or more that isn’t.
