Installing Font - Step 2 - Stuck
Adding a new font documentation says:
Secondly the font must be installed by opening the Edit form and pressing OK
Where is the Edit form located so I can click OK? I’ve selected Edit on the row of the font in the library and Saved the edit. That didn’t do it.
Can someone point me in the right direction here?
Thank you!
Yup that’s pretty much it. Make sure you clear the browser cache (shift+F5 should be enough), new font should be available to select in text editor.
Browser cache - that did it! Thanks, Peter.
