hello, I have installed xibo several times with Windows and packages like xampp. I was asked for a configuration with Linux so I downloaded from turnkey the distro lamp that uses mySQL Apache and Maria DB. PHP works smoothly because PHP info opens. if I try to start the xibo installation it returns an error 500. the base distro is a Debian. the destination folder is reachable because I copied the PHP info inside this folder and it opens regularly. some advice?
