Installation Method
Custom install
Operating System
Ubuntu 24.04.4 LTS
When installing Xibo CMS, some questions and issues came to show. Major and minor, that i cannot find answers to in the documention. This is the third. ![]()
Installing and configuring XMR.
The docs states that XMR is included in the “/vendor/bin” folder and that i should create a config.json there. I see no trace of an XMR or the PHAR file that i understand should be here somewhere.
After some googling, i found some year-old threads stating that i should download it separately (and that i should not be included in the release), and precisely version 1.0. Since that post was made there are newer versions up to 1.3.
The github page that contains the XMR states that:
If you are here for anything other than software development purposes, it is unlikely you are in the right place. XMR is shipped with the Xibo CMS installation and you would usually install it from there.
The docs also mentions an example upstart conf file in vendor/xibosignage/xibo-xmr/bin/upstart, but the xibo-xmr folder does not exist.
I would like to see that example file, but i also wonder what more that folder contains.
I can continue to make tests to make this work, but if someone know more precisely what should be done with the XMR it would save me a lot of time. ![]()
Thanks in advance
