INSTALL ERROR Please help
Hello, I have tried to install Xibo on 2 different windows10 machines and I can’t get through it. When trying to “use existing database” I get this error:
An error occurred populating the database. Statement number: 57. Error Message = [SQLSTATE[HY000]: General error: 1005 Can’t create table xibo.#sql-3f10_20e (errno: 121 “Duplicate key on write or update”)]. File = [Array]. SQL = [ALTER TABLE blacklist ADD CONSTRAINT blacklist_ibfk_1 FOREIGN KEY (MediaID) REFERENCES media (mediaID), ADD CONSTRAINT blacklist_ibfk_2 FOREIGN KEY (DisplayID) REFERENCES display (displayid)].
Thanks for any help.
The existing database must be empty - otherwise you need to create a new database. It looks very much like you are trying to install into a database that already has content in it?
I was following step by step the Diy Digital Signage youtube video. Everything was easy and worked up until that point of “use existing database”. Once again this is on 2 different win10 machines.
Here is a link to the video.
minute mark 10:04 in the video.
