Install a xibo-player on raspberry Pi4
I just bought a Raspberry Pi4 and i would like install xibo player.
it is not compatible with arm64 when i want install it on ubuntu.
Is there a solution to install it on Raspberry.
Thanks ,
damien
Thank you for your message and welcome to the Xibo Community! Raspberry PIs are not officially recommended as a hardware solution for the Xibo Player due to compatibility issues and possible performance issues.
You may find that others have discussed their experiences with PIs on other sections of the Forum, such as Hardware and perhaps even the Android channels. I hope you are able to find other members of the Community who may be able to help you set up a Player or provide more information about their experiences so you can make an informed decision on whether to proceed. Please do keep in mind that performance cannot be guaranteed and you should be sure to thoroughly test any PI setups before using them for your digital signage.
