every XMR action (for example commands, screenshots and reconfigure XMR) i try to perform is loading infinite.
The Client only receives heartbeats if i start xmr.phar manually. Is this an normal behavior?
ZeroMQ is recognized from Xibo (checkmark on the Fault Report page).
In debug mode client and cms sided there aren’t any errors.
Is there a possibility to check the connection between CMS and ZeroMQ?
Thank You
