on 05/10/2017 a staff member asked me to use the xibo to display some maps, so i did and they ran fine, but after that date i have went to look at teh layout again as it can be used sometime next month for a event, and the images look like this:
as you can guess this will not play the images. i have check the media and that is currupted also, its not urgant as i keep all the xibo media in a seperate folder on the CMS so i can just reupload it, but its just annoying to have to keep doin this.
As i said it is fine before it plays, then it plays and then that happens
both the player and the CMS are pointing the users documents to a XIBO folder, we are running the CMS 1.7.7 and the same version for the player, they are running on a windows 10 machine that is logged in with a local administrator account, there is nothing special about the setup, it has not really changed since it was put in, it is used as a its there and only one user me has access and can add layouts and media.
if there is anything specific you would like to know just ask, but as I can see nothing is special not extra modules or anything
