I want to upgrade CMS Xibo from 1.8.1 to 1.8.5 manually
I want to upgrade my cms to latest version 1.8.5 manually, at my company want to upgrade cms without docker, i’m so confused which one to download from this link : Github
i just want to upgrade cms, which one i must download from release new version ?
i think maybe “xibo-manual-1.8.5.zip” or all of file on release new version,
i hope anyone can help me.
thanks ~
The CMS files are contained in https://github.com/xibosignage/xibo-cms/releases/download/1.8.5/xibo-cms-1.8.5.tar.gz
^^ this is the user manual as seen here Xibo Digital Signage
thank you for you reply , it possible to make my custom page and adding new column on database not disapear after upgrade ?
There isn’t anything in the upgrade that would remove your column from the database - however your custom page would have to be re-implemented (if you’ve modified a system page). If its standalone and you’ve implemented the controller/route config via custom middleware, then it will remain as it was before upgrade.
thanks , this is help me so much.
