I need help for send media file to client ubuntu 12.04
Hello:
I’m working with version 1.6.4 of Xibo . When the server sends video files to the client Ubuntu 12.04 , these still tend to be transmitted , its size is doubled and start airing again. I installed the mod_xsendfile module for apache and the problem continues . Please I need help …
please anyone has any Iddea of what might be happening ?
Hi
I’m afraid the Linux player isn’t developed or supported any longer. Sendfile won’t make any difference to file downloads as they’re served over the XMDS SOAP web service on that Player.
You should upgrade to something current and supported and I’m sure it will then work reliably.
Ok Alex thank you very much anyway.
