I have issue about xibo dotnet player v4
I run xibo cms with docker but my player can not update schedule how to fix this ?
thank you
Hi Natthaphum_Champalee, welcome to the community!
That error suggests that your player is having an issue switching to using HTTPS. Are you using HTTPS/SSL with your self hosted CMS?
If you are not, please make sure that you do not have force HTTPS set. There is a global setting and a player profile setting that you will need to check. I have included instructions below:
Global Setting:
This can be found under the Settings menu in your CMS, on the Network tab.
Player Profile Settings
If you go to the Displays menu in your CMS and click the button at the end of the entry for your player. Choose Edit from the menu. When the Edit Display window opens go to the Settings tab and you will see the Force HTTPS option.
Can you let me know if un-setting the force HTTPS setting resolves the error?
Many thanks.
