How to view one layout splitted in two/three players
Hi, I created different layouts at the resolution of 2840x1080 (Full HD x 2). I have the need to view each layout splitted over two player installed on two different PCs (Intel Compute Stick). Currently it work only using two outputs of the same PC. Thanks in advance.
Xibo doesn’t support synchronised playback across multiple screens.
The ways you can accomplish that is with a PC with dual display outputs and extended desktop in Windows, or using a matrix scaler (video wall scaler) to split the single HDMI output from your device and deliver it to multiple displays.
