How to upgrade Xibo CMS from 1.7.9 to 1.8.1
I am currently running Xibo on a Windows Server 2012 with Xamp. I would like to upgrade to at least 1.8.7 but I read you should go to 1.8.1 first if you are at 1.7.9.
I have been looking around and I can’t seem to find a how to. It has been a while since I have needed to upgrade Xibo as it’s been working fine. We would like to use WebOS now and it requires 1.8.7.
Can anyone please help?
I have the 1.8.1.tar.gz file and I know I am supposed to put it somewhere but I can’t remember where and I couldn’t find the answer as I looked around.
Please help:)
I can’t seem to find the installation folder the files belong in
Do I replace what’s in the xampp\apache ?
We have CMS upgrade instructions in our Administration manual, please select the appropriate instructions for your environment.
If you do have further issues or require assistance then please do come back to us.
Thank you
