I have custom module and wish to show some notifications to users of Xibo UI regarding certain events.
Is there any way to do it? if yes, how and example code will be very helpful…
Thank you
This should be possible - although i’ve not tried it you would need to use the event dispatcher to raise a custom event, and add some middleware to catch that event and create the notification.
In the custom folder, create two classes - MyNotificationMiddleware
and MyNotificationEvent
MyNotificationEvent
namespace Xibo\Custom;
class MyNotificationEvent extends Event
const NAME = 'my.notification.event';
public $module;
public function __construct($module)
$this->module = $module;
class MyMiddleware extends Middleware
public function call()
$app = $this->getApplication();
$app->hook('slim.before.dispatch', function() use($app) {
/** @var EventDispatcher $dispatcher */
$dispatcher = $app->dispatcher;
$dispatcher->addListener(MyNotificationEvent::NAME, function(Event $event) use ($app) {
/** @var MyNotificationEvent $event */
$module = $event->module;
// Use the module information to create a notification with the notificationFactory
/** @var NotificactionFactory $notificationFactory */
$notificationFactory = $app->notificationFactory;
$notification = $this->notificationFactory->createEmpty();
$notification->subject = '';
$notification->body = '';
$notification->createdDt = $app->dateService->getLocalDate(null, 'U');
$notification->releaseDt = $app->dateService->getLocalDate(null, 'U');
$notification->isEmail = 0;
$notification->isInterrupt = 0;
$notification->userId = $app->user->userId;
$notification->assignUserGroup(<userGroupId>);
$notification->save();
// Next middleware
$this->next->call();
Your Module
In your module, at appropriate times, use getDispatcher
to create and raise your event.
// Create the event and pass it your module
$event = new MyNotificationEvent($this);
$this->getDispatcher()->dispatch($event::NAME, $event);
settings.php
Wire up your new middleware in settings.php
// Additional Middleware
$middleware = [new \Xibo\Custom\MyNotificationMiddleware()];
