How to setup display resolution
I found where to set display resolution for layout but where do i set it for displayes, or is it set to actual resolution?
Hi, the display resolution is chosen when configuring content (Layout / full screen Image/Video/Playlist content) and should match the screen dimensions of the intended displays to show the content on.
You can create your own resolutions from the Design > Resolutions page of the main CMS menu.
I hope that answers your question.
