How to set text into middle of region
How to set position text into middle of region (redline)
So you could either just add some new lines (hit enter few times)
Or perhaps create a table with width/height same as your region, align it to centre and remove the border (so it doesn’t look like a table, but you will be able to add text in the middle of your region)
to make it easier, for example, full screen ‘table’ with one row/column would be like this:
<table align="center" border="0" cellpadding="1" cellspacing="1" style="height: 1080px; width: 1920px;">
<tbody>
	<tr>
		<td style="text-align: center;"><span style="font-size:48px;"><span style="color:#FFFFFF;">RANDOM TEXT</span></span></td>
	</tr>
</tbody>
so it will look like this:
Thank you Peter. It’s work fine for me. so if I would like to set ticker rss into middle of region. What should I do.(Can’t use hit enter few times such as normal text)
Edit. Just use <.br> to sliding ticker rss down.
I am glad that you worked that out.
I’ll close this topic now.
