hello, i need your support!!!
i had xibo android client install on 42 monitor and using xibo cms v1.8.3.
I want to update contents using Xibo API (Text Widget) and send signal to Xibo android client to download contents change from xibo server.
what is method i can do that?
thanks for your help!
