How to play radio stream on android box besides xibo
Sorry for being a little off-topic but I’d like to setup a radio stream on a minix x7 based xibo installation.
Instead of using xibo’s audio feature, I was thinking of using a separate android app but I have some concerns about that.
1 - I should set it up as autostart (should not be a problem)
2 - it should be reliable (recover after internet connection loss for example)
3 - Ideally, there should be a way to manage the player remotely (managing the x7 is a bit delicate due to its physical location)
If you have any comment/suggestion to make, they would be welcome
Mikael
