How to eliminate delay when rendering Images and Text together?
Hi All
I’m running a layout that has multi regions, there are 4 regions that contain images and 4 have text (their names). The problem I have is Text and images are not rendering at the same time so there is a delay of second or two, how can I eliminate this delay?
Many Thanks
What CMS / player version do you use please?
It would be best to use 1.7.8 and IE11, there might be some delay hardware dependant, although 2s seems like a lot in this case, unless your images have really high dpi.
Thanks for your reply, I’m using 1.7.8 CMS & XiboClient and Microsoft edge as web browser images are very normal taken from the net. One thing I must mention this delay is only on Client screen not on preview.
