How to edit Advanced display settings in XIBO
Hello I am trying to change the following parameters in
Displays>(Display Select) Edit>Advanced
the current “Advanced” settings are as follows
Settings Profile? = Windows
Interleave Default = No
Auditing = Yes
Need to change the following
Collect interval 15 minutes (need to change to 5 Minutes)
Download Window Start Time 11:01 (need to change to 7:30)
Download Window End Time 11:01 (need to change to 18:30)
Enable PowerPoint? 0 (need to change to 1)
I am new to this tool - just installed the CMS and first client 24 hours ago
also I have to keep restarting the client for it to pickup the latest changes - am I doing something wrong ?
thank you
Display settings -> edit display profile assigned to your device -> make changes and save
Of course make sure this display profile is assigned to your device.
Hello Peter
I did not understand your instructions
to access the display settings I do the following
Displays -> Edit->…etc
would you please explain how to get to these settings that you have described above
thanks for your assistance
Simon
Never mind…I got to the page you were talking about
regards
Simon
