How to edit a region behind a template with a higher z
Hello Everyone,
I have a few regions that need their media (image) changed frequently. Let’s say they are layer 2. On “top” of them, I have as you suggested a full screen image with transparent areas set to layer 3. I would expect that if I change it from later 3 to 1 it moves behind the active regions so I can edit them but that’s not what happens. The full screen image with the transparent areas seems to alway be “on top” of my active regions and I cannot click on their controls.
How can I change the images in the regions without resizing the full screen image to get to the regions behind it all the time?
-Tony
We do have it logged and that’s something we will look into as big/full screen floating regions do indeed prevent you from editing anything ‘behind’ them.
In the meantime you will have to move/resize it I’m afraid, alternatively you could use API calls do that without even touching the designer.
