How to display layouts one after another in a campaign?
I am having multiple layouts in a single campaign and I want to schedule layouts to display one after another with transition or some effect.
Kindly guide me about the steps in this Xibo CMS.
If you schedule whole campaign to the display(s), then it will show the layouts in the same order as there are in the campaign.
Transitions can be added to widget and end transition can also be added to region - transitions will only work on Android player.
