How to create a random display of layouts?
I have a Campaign of news-related Layouts that runs for about 4 minutes.
I have a further set of about 20 videos, each of a minute or two each.
I would like to display ONE of the videos between each run of the Campaign. The one chosen could be random or in a sequence, it doesn’t really matter.
Is there any easy way to do this? (Without scheduling everything separately which would seem to be tedious and difficult to maintain/understand afterwards).
Thanks in advance.
You can use a campaign to order your layouts in whatever sequence you want. You then just schedule the one campaign.
It’s not possible to add a random layout to a campaign so you would need to define an absolute order in there, but it will be much more straight forward than trying to do that in the schedule.
