Hi
Can any one tell me the step by step process of currencies exchange raters configuration in xibo
Hi
What seems to be a problem please?
Assuming you have added the API key already to the module configuration - Currencies | Xibo Digital Signage
All you need to do is add the widget on the layout, select template, define items (currencies) and base currency to get the rates ie
