How to check first access date by each display
I check in the system only show the last access from the display. I but really want to know how can I check which date that my display first access to this system.
Can u reply as soon as possible?27c0c12cd89349a9d28f413354352a3ef9959199_1_378x500
Xibo does not store the date that a Display is first connected to a CMS, my apologies for any inconvenience.
Depending on the OS your Player was installed on, you may be able to locate the Install date in the System settings, but this is not guaranteed.
