Are you having trouble syncing your Xibo CMS display schedules with your local timezone? Or having similar Problems? It’s a common issue, but easy to fix! Here’s a quick guide on how to change the timezone in your Xibo CMS:
- Log in to your Xibo CMS dashboard.
- Navigate to Settings (found under Administration ).
- Look for the Regional tab.
- Select the Timezone section.
- Select your desired timezone from the dropdown menu.
- Save your changes.
That’s it! Your Xibo CMS will now display schedules and times according to your selected timezone. If you don’t see your changes immediately, log out of the CMS and then log in again.
Hope this helped you.
