Hello Guys,
I am trying to compile the player from source code under the Ubuntu 18.04.
I created a build subdirectory in the root of the xibo-linux-develop. I started cmake from this directory by providing the source code folder as …
All libraries checks are passed correctlyu but I get a configuration error as follows:
$ cmake …
– The C compiler identification is GNU 7.4.0
– The CXX compiler identification is GNU 7.4.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found PkgConfig: /usr/bin/pkg-config (found version “0.29.1”)
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Found Boost: /usr/local/include (found suitable exact version “1.70.0”) found components: filesystem system date_time thread chrono atomic
– Checking for modules ‘gstreamer-pbutils-1.0;gstreamer-video-1.0>=1.14.0;gstreamer-plugins-base-1.0>=1.14.0’
– Found gstreamer-pbutils-1.0, version 1.14.5
– Found gstreamer-video-1.0, version 1.14.5
– Found gstreamer-plugins-base-1.0, version 1.14.5
– Checking for module ‘webkitgtk-3.0>=2.4.10’
– Found webkitgtk-3.0, version 2.4.11
– Checking for module ‘gtkmm-3.0>=3.22.0’
– Found gtkmm-3.0, version 3.22.2
– Checking for module ‘glibmm-2.4>=2.56.0’
– Found glibmm-2.4, version 2.56.0
– Checking for module ‘spdlog>=1.4.1’
– Found spdlog, version 1.4.2
– Found GTest: /usr/lib/libgtest.so
– Checking for module ‘libzmq>=4.3.0’
– Found libzmq, version 4.3.2
objdump: ‘a.out’: No such file
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
GMOCK
linked by target “schedule_tests” in directory /home/liatoss/Downloads/Xibo/xibo-linux-develop/player/schedule/tests
linked by target “common_tests” in directory /home/liatoss/Downloads/Xibo/xibo-linux-develop/player/common/tests
– Configuring incomplete, errors occurred!
See also “/home/liatoss/Downloads/Xibo/xibo-linux-develop/CMakeFiles/CMakeOutput.log”.
See also “/home/liatoss/Downloads/Xibo/xibo-linux-develop/CMakeFiles/CMakeError.log”.
Do you have any idea how to fix the problem?
Thank you in advance, Vlad.
