How to add a new Module in Xibo?
Dear Sir,
I’m using xibo 1.4.2 since 1 year,i want to add a new module (like Audio) .
Can u pls tell me.
Thanks,
Tusar
Modules are not supported in 1.4.2 - ideally you should be using the new module system in 1.8 which is documented here: http://xibo.org.uk/manual-tempel/en/advanced_modules.html
I’m new to PHP it is difficult to understand the control flow of the source code for me.
Is there any guide for me.
Sorry, we don’t have an in depth guide to writing modules at the moment - that is something we want to get done for the 1.8.0 release.
The best I can suggest is to look at one of the other modules - like finance.
