I have an image as a title in the same region that the weather forecast is shown, but apparently it is not work to insert it in the same way as a text module, because it is not shown. in the first line I am trying to add the image here:
how should i write the source? thanks!
@natasha would you help me with this, please?
You need to use a library reference rather than the URL. So change your code to:
<img src="[95775]" />
The visual editor in the text module does this for you when you load/save - but in raw HTML boxes you need to use the reference.
Thanks, Dan
