Dear Xibo Staff,
I have a problem with the installation of Xibo183. I’m using the ufficial guide in this page ( https://www.xibo.org.uk/manual/en/install_docker_linux.html ). I did everything but I can’t see the cms.
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
7e7af1a2df5d xibosignage/xibo-cms:release_1.8.3 “/entrypoint.sh” 7 minutes ago Up 7 minutes 0.0.0.0:65501->80/tcp xibodocker_cms-web_1
d7134b887237 xibosignage/xibo-xmr:release_1.8.3 “/entrypoint.sh” 7 minutes ago Up 7 minutes 50001/tcp, 0.0.0.0:65500->9505/tcp xibodocker_cms-xmr_1
06c456c1ebc0 mysql:5.6 “docker-entrypoint.s…” 7 minutes ago Up 7 minutes 3306/tcp xibodocker_cms-db_1
the cms is in a remote private server at this IP 94.76.229.43
So I can’t try the localhost, I suppose.
I’m using the custom ports file
docker-compose -f cms_custom-ports.yml up -d
version: “2.1”
services:
cms-db:
image: mysql:5.6
volumes:
- "./shared/db:/var/lib/mysql"
restart: always
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_RANDOM_ROOT_PASSWORD=yes
mem_limit: 1g
env_file: config.env
cms-xmr:
image: xibosignage/xibo-xmr:release_1.8.3
ports:
- "65500:9505"
restart: always
mem_limit: 256m
cms-web:
image: xibosignage/xibo-cms:release_1.8.3
volumes:
- “./shared/cms/custom:/var/www/cms/custom”
- “./shared/backup:/var/www/backup”
- “./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom”
- “./shared/cms/library:/var/www/cms/library”
- "./shared/cms/web/userscripts:/var/www/cms/web/userscripts"
restart: always
links:
- cms-db:mysql
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
ports:
- "65501:80"
mem_limit: 1g
The CMS should be at http://94.76.229.43:65501/ …
Thanks in advance for any suggestion…
