Greetings again,
I’m trying to make my own android app for xibo, I managed to use RegisterDisplay/RequiredFiles/GetFile I got the layout id from the RequiredFiles call and then the mediaId/regionId/ from the decoded xml file of the layout. However when I try to use GetResource I get a “Requested an invalid file.” when I want to test before coding on postman . Below my postman envelope and the xml data of the layout:
Postman envelope I tested with:
<tns:GetResource>
<serverKey xsi:type="xsd:string">mykey</serverKey>
<hardwareKey xsi:type="xsd:string">smthing</hardwareKey>
<layoutId xsi:type="xsd:string">3</layoutId>
<regionId xsi:type="xsd:string">5</regionId>
<mediaId xsi:type="xsd:string">5</mediaId>
</tns:GetResource>
Xml layout data decoded:
<?xml version="1.0"?>
<layout width="1920" height="1080" bgcolor="#000" schemaVersion="3">
<region id="5" width="902.4000" height="1080.0000" top="0.0000" left="1015.2001"><options/>
<media id="5" type="image" render="native" duration="10" useDuration="0" fileId="21"><options><uri>21.jpg</uri></options><raw/></media>
<media id="6" type="video" render="native" duration="0" useDuration="0" fileId="22">
<options><uri>22.mp4</uri><mute>0</mute></options><raw/></media></region>
<region id="6" width="892.8000" height="1012.8000" top="50.0001" left="50.0000">
<options/><media id="7" type="video" render="native" duration="1" useDuration="0" fileId="22">
<options><uri>22.mp4</uri><mute>0</mute></options><raw/></media></region><tags/></layout>
Any idea what I’m missing?
Also, let’s say I got all the data I need from the CMS, if I understand correctly I need to put the info from GetResource into a web view no?
I’d really appreciate any help, this is currently my end of studies project and I want to finish it as soon as possible.
PS: On a side note, do you recommend using Retrofit? I’m currently using AsyncTask but I’v read Retrofit is faster.
