Freeze area ? it's possible?
I would like to freeze areas. is it possible ?
example: 3 differents users with one area each
each user can only put an image,video… on the area but can not change the size of the area.
only administreur can create / edit area. the user can only change its content (jpeg, avi …)
it is possible to block areas ?
Thank you
seb’s_FR
In order to edit the layout, the user must have permission to edit it. That will allow them to create new regions.
Existing regions have permissions and you can prevent users or groups from making changes to them.
how can i prevent users or groups from making changes to them ?
2 users:M Dupont = admin and M Durand no Admin.
I want the admin user created 3 regions.
And I want the second user (M Durand) can not change the size of the regions(the region made by Mr Dupont).
But Mr Durand can add media in the area only.
I dont want M Durand changes the size of the regions. only admin.
is what I explain me?
I can not do with the setup of permissions.
it is possible to change the code?
it is possible to block the right of writing a file?
Thank you.
seb the xibo french user.:wink:
