I’m guessing its because forecast io is now dark sky but the weather module appears to be broken now. Any way to get it working or just wait for the new xibo?
I’m not aware that it’s broken.
The module has been updated in 1.8 series to reflect their rebrand, but the API calls all remain the same to the best of my knowledge.
I’ve checked it on a CMS here and it appears to be working. Make sure your API key is correct, and set under the module settings, and then add a weather widget, and head to the Forecast tab in the module properties, and click “Request Forecast”. It should return raw forecast data.
Sometime around when they got hacked my curl certificate stopped working figured it out thank you
