Forecast icon not show completed
i have a problem, the forecast icon when run on IE (9 or 11) don’t showed completly but on Chrome show correct.
I test creating a Key on the regedit but the IE do nothing…
Can You helpme??
So you will want to add that reg key for IE11 for Xibo to use.
You will also want to move your regions so they don’t overlap and use 1.7.7 CMS and client versions if you don’t already.
