Force determine duration of playlist
Is there a way that you can force determine the duration of a playlist? Currently, we have a layout of only a couple of different playlists, but we cannot publish the layout because it currently has no time (as the playlist has no items), which makes it invalid. When you go to publish the layout, it times out.
At the moment you need to add an item to the playlist in order to publish it.
There are items in all of the playlists, but under the Duration column, is says ‘Changes have been made and we are recalculating this Playlists duration’. Which therefore means that the layout has no duration as there is no time.
Even with layouts with a determined time, the layout still appears invalid and it returns an error message saying that there is an empty region, which there isn’t.
