Flip clock for android
when we added a flip clock in a layout at android player, seconds isn’t series and is delayed. How to solve this problem?
It is a 3rd party library, we are currently using v 0.6.2, so that’s probably why you can encounter some bugs with it.
Although I think that if the clock isn’t really big then it should still display time decently. When it is big, then yes, it will be a lot of shuttering/even freezes generally far away from smooth display.
Thanks,
Peter
