FLIP Clock as Timer - Client Issue
#1
Hi Xibo Team!
Good day,
I have an issue with the FLIP CLOCK used as timer, in the CMS & Layout preview, the timer I made for a specific date is working, but when pushed and viewed to my client displays it’s just displaying “00:00:00:00”
I already checked my set timezones in both the client and CMS, all are in sync and same timezone, but still the issue persists.
I already tried restarting the client and the client machine, but still the issue persists.
There are also no overlapping regions
I also tried “VERIFYING” all module, but still no luck.
CMS Version: 1.8.2
Client Version: 1.8.18
Please see attached screenshot for visual reference.
#2
Please also see my CLOCK settings
Countdown is from August 5, 2018. (Please see screenshot)
#3
I’d try setting the offset to
2018-08-07 12:00:00
I’m not aware of a specific bug, but 1.8.2 is now 8 minor versions out of date, so you might consider upgrading to 1.8.10 too.
#4
Alright, we’ll try to upgrade and see what happens.
No luck, for the changing of offset. I already tried later dates like August 20, but still no luck.
I also tried to check the FLIPCLOCK file (.htm) under the Xibo library in the client machine, and its running perfectly. I don’t know why the clock is not working, when viewed in the Xibo Client.
Maybe this issues is still worth checking for your team,
Thank you Alex as always,
#5
Hi @jcmacalindol
I’m no expert and it sounds to me like you know more about this than I.
But I was able to get a countdown working by setting the duration to however many seconds I needed it to count down. Hopefully this is what you were looking to do.
#6
Hi Ryan!
Good day,
I haven’t thought of doing that, let me try it next time!
But I think we have different requirements, did you try setting the OFFSET with the same pattern as mine?.
Thanks for this though, I will definitely try your solution next time!
Have a great day Sir! :slight_smile:
#7
I did try using the offset with the same pattern as you did, but I couldn’t tell it was changing anything.
The clock always started with whatever I set the duration as.
My original requirements can be found here. https://community.xibo.org.uk/t/countdown-timer/7585
I’m hoping one day the Clock widget will have a timer option and allow you to set a future date and time and will automatically calculate the time that needs to be displayed on the timer.
#8
Hi
Hi Guys,
I dont know, but it seems to be a new bug/issue in the new 1.8.12. release ?
The Flipclock in the preview works fine, everthing is ok, but on the Client it shows only 00:00:00:00.
Xibo-Client Version is 1.8.12-133 on windows 10
My offset is 2019-03-01 12:00:00
Have anybody the same issue?
Sunny Greetings from snowy Germany
Torsten
#9
I have been trying to replicate the issue you described but without success. Can you send me an exported copy of your Layout in a private message so I can try your Layout on my setup?
Thank you for bringing this to our attention. I have created a Bug report for this issue, the Development team will resolve the issue as soon as possible. I have included a link to the report for reference:
My apologies for any inconvenience while this issue is resolved.
Hi Guys,
I dont know, but it seems to be a new bug/issue in the new 2.0.0. release ?
The Flipclock dosen’t work in preview. It shows only 00:00:00:00.
Xibo-CMS is 2.0.0. Player is on Windows 2 R200-200
My offset is 2019-03-30 12:00:00
Torsten
#12
Thank you for your message. I have created a Flip Clock with the below settings in CMS version 2.0.1 and found that it is showing the countdown without issue.
I have also set the Clock Face to 12h Clock and 24h Clock without an offset and was able to see the time in Preview layout. I would recommend upgrading your CMS to 2.0.1 to see if this resolves the issue. If it does not, please post the settings for your Widget as well as a screenshot of the zeroes you are seeing.
HI Daniel,
Ok, i think i must explain the issus better:
Server: Xampp on Win 10. Xibo 1.8.12
I create a layout with one region, an put the clock widget in it.
Settings: Flipclock , Daycounter, Offset: 2019-04-19 12:00:00
Now in the previewmode everthing work fine (same as on your System), but not on my Display:
Display: Intel Stick PC with Win10 an Xibo Player Windows 2 R200-200
On the display it shows only 00:00:00:00
I setup a Testserver with 2.0.1 and report here again…
Greetings Torsten
#14
i install a testserver with xampp on win10 and xibo 2.0.1
Then i create a layout with a flipclock like the same settings as above.
00:00:00 in Previemode, in the Preview and on the Display.
Work worse than befor in Xibo 1.8.12.
If you want i can send you the layout to do some testings?
Greetings from Germany
Torsten
#15
Thank you for the message and further information. You are correct that the V2-200 Player is also affected. A fix is currently in development and will be included in a future release of Xibo. Once again I appreciate the information you provided.
Regarding the preview shown in your image from the last message, the Offset is set to 2019-04-04 16:00. Can you change that to 2019-04-19 12:00:00 to see if the Preview then shows the correct Countdown? I ask because I still can’t replicate that in my 2.0.1 CMS:
Hi Daniel
your wish is my order:
Greetings
Torsten
