Filetype not allowed
Hi All,
in Region-Timeline trying add new video .MP4 or .WMV size 1.5 GB and I’m getting " Filetype not allowed".
The PHP setting is up to 5000M (Add New Video: "This form accepts: wmv, avi, mpg, mpeg, webm, mp4 files up to a maximum size of 5000M ").
Could someone let me now why I’m not able to upload .MP4 or .WMV files?
Thanks in advance for any advise,
Ebi
By chance did you update both parameters in the php.ini file? I believe you need to update both.
upload_max_filesize = 5000M and post_max_size = 5000M
Yes I have already set upload_max_filesize = 5000M and post_max_size = 5000M
. I tried all supported format by Xibo, but I only can upload Video files which are less then 800MB.
It is frustrating… I have to cut videos short less then 800m to upload:-(
I have not tried it, but I believe you can copy files to the client and configure the player to play them (don’t have to upload to CMS. You rather distribute them first in a different method of your choosing). I’ll try to take a look at that tomorrow and will report back.
