Filename column in Grid playlist in 1.8
Hi, just wondering how I would go about changing the “Name” column to “Filename” in the grid view of the playlist editor. I much prefer to see the actual filename instead of the name. Even better would be to replicate the functionality of the media browser where you can select your own columns like thumbnails etc.
Actually, looking at it again I think perhaps this is the intention already that it should be the filename showing. Currently all I get in the name field is “image”. When I look at the “Assign an item from the Library” view, it does show the filename under the name field for images. Is this a bug?
Yes, it does look like a bug.
I’ve created a bug report for it:
