Good Day,
I know this is probably an unusually request but im going to give it a shot anyway. I currently use Xibo to do some Digital Signage stuff in our retail locations, mostly wall mounted TVs with an attached player.
Our POS company has a feature where you can display ads on a secondary montior that is attached to the POS. You can purchase their hosted package or simply run the Ads off a local windows folder. I currently have a process set up that copies from a centralized set of folders each night to the individual POS machines. The problem is that it lakes scheduling and I am often trying to remember how to do everything manually.
I tried setting up Xibo on my test machine to run on a secondary monitor but struggled with getting the player and resolution to work correctly. I was wondering if there was a way to use the player to simply cache the files on the local machine for me. Basically the player would not run, but would make sure to download the files from the CMS and synch them to a local folder on the PC. I would use the built in feature of my POS software to then display the content.
Anyone have thoughts on this?
